Mysterious crashing - PLL issue
A project log for Gadget
USB-gadget-based Bus Pirate-style hacker toolkit for Linux boards (targeting Pi Zero for now)
usedbytesusedbytes 03/28/2016 at 20:162 Comments
I'm mainly writing this here so I've got something to refer to.
I've got the base system running how I like now. It boots, starts the USB gadget serial and ethernet, and registers a link-local IP address. I've got AVAHI running, so I can find the board by hostname. So far so good. Boot time is currently sitting between 10-12 seconds.
Next I wanted to free up the serial port (i.e. no console logging on the serial port). It works OK, as long as you never ever use the serial port!
So:
We're talking hard hang, LED doesn't flash any more etc.
I thought the kernel was panicking - but without the serial port console it's impossible to tell. I added some print statements in the relevant parts of the kernel and it looks like it's making it through all of the tty/serial code just fine. It actually crashes *after* minicom exits - this doesn't really match up with a panic. It there were a panic it should happen during the exit sequence.
After some lucky Googling, I found this thread: http://lists.infradead.org/pipermail/linux-arm-kernel/2016-February/406730.html, which indicates that there's a problem with the PLL refcounting, which means the PLL can get turned off when the PL011 (serial) driver isn't in constant use.
I commented out the clock reference count decrement in the PL011 driver, and bam! Everything works. So that's not a proper fix but at least I know what the problem is now.
My next step is probably to switch to a 4.5/4.6-rc1 kernel (I'm currently on 4.5-rc7) and see if any of the recent bcm283x clock changes I've seen flying through the mailing list fixes the problem.
What better way to spend a Bank Holiday Monday?
usedbytes wrote 03/29/2016 at 21:22 point
Note to self - apply this patch-series and see if it helps matters: http://lists.infradead.org/pipermail/linux-rpi-kernel/2016-February/003503.html
usedbytes wrote 03/31/2016 at 20:50 point
Confirmed - this patch fixes the hang. All good, hopefully it makes its way into mainline soonish.
