Display:
Top Digit shows hours, bottom-right is 1, left is 2, top-right is 4 and left is 8, lastly middle segment is 16.
Middle Digit shows minutes, same as hours, with difference that instead of the middle part showing 16, I assigned the middle-right to display 15, middle-left displays 30, so reading minutes is a lot easier :)
I also included a second Indicator on the Dot, so I know the Clock is actually working.
As one can see, the images were taken at around 13:20-13:21.
