Pi Power Management
A project log for Raspberry Pi Head Unit
Bringing Bluetooth/wifi streaming and USB/SD Card music to my auld car via the head unit's CD Changer port
craig-hissettCraig Hissett 01/10/2017 at 10:240 Comments
Just a quick post to share this link that uses an USB Powerbank as a UPS-style system, using a network switch to simulate the power outage (when the power is cut to the Pi and the Network switch the network connection goes down and the Pi detects it).
I could modify this to trigger a safe shutdown when the car is switched off. If there's a way to do it without the network switch that would be bloody marvellous!
http://raspi-ups.appspot.com/en/software.jsp?_utm_source=1-2-2
