After doing the presentation at the HaD 10th anniversary convention I have been inspired to finish this project.
Parts sufficient to construct the ALU have been placed on order, I am going to be working with the vishay DG403 chip, and plan on building it in such a way that I will probably end up with a hybrid ternary/binary cpu.
I have removed the kleene logic table as it seems to confuse people in that it is more of a philosophical thing as apposed to a pure logic meant for use in a CPU ^^;;
The logic tables for doing math are as follows,
The chip in question appears to almost be ideal for the situation,
In other news, I have been toying with the idea of playing around with magnetic core memory, the final plan will most likely to use a transistor based memory system, however sometimes it is fun to look at older tech.
More to come after I receive the components and begin a proper build! :D
Thanks everyone for your support!
Now back to studying for midterms.... the joys of going back to school :)
~ThunderSqueak
ThunderSqueak
