New delrin V wheels to improve performance
A project log for Sienci Mill One: Simplifying Desktop CNC Milling
CNC desktop machines are expensive and complicated. This machine changes all that.
andy-leeAndy Lee 07/08/2016 at 18:460 Comments
July 8, 2016
13558844_1735683886688480_3197959458401533695_o
Previously we were using steel 624vv v wheel bearings (and the family of 6–vv bearings) that were low cost and worked well with our machine, but we found that the small amount “wobble” in the bearings was translated into good-but-not-as-good-as-it-could-be performance.
So we started testing out Delrin V wheels you can find on a lot of other machines. They look like this DSC04034__50579.1425747043.1280.1280.jpg
and with the two bearings sandwiched together, eliminates that “wobble” we were finding in the other bearings.
These wheels will also come with eccentric nuts which means you can adjust the tension (or preload) on the wheels against the rails.
Previously we were hesitant on using these types of wheels because of their higher cost, but we’re excited to share that we have found a supplier who is offering them at a very affordable price. There is a small increase in our BOM, but we believe that it is worth the extra cost to bring you higher performing machines.
Expect to see faster milling rates on harder materials like aluminum, as well as better finishes on the milled parts in the time to come!
