::Building The Java Codes::
A project log for CORTANA BAND
This is a gesture and voice recognition based device.
karthik-raviKARTHIK RAVI 05/27/2016 at 16:460 Comments
Java coding using the package RxTx has to be done. These packages are available open source and they are downloaded. The function of the library are checked through online and serial communication examples and they are built.
Basic serial communication code is run and check for any errors prones.
(The complete java code has not been linked)
