Prototype Development - 2
A project log for CORTANA BAND
This is a gesture and voice recognition based device.
karthik-raviKARTHIK RAVI 05/27/2016 at 16:550 Comments
Bridging the directions with the application using java codes and checking responses.
The baud rate of arduino uno is checked and used in the java code. the uart communication is established in the COM port to receive the data serially.
