Circuit day 1.
A project log for OSPb - An Open Source Lead Tester
An open source design for an inexpensive colormetric test.
matthew-edmondMatthew Edmond 03/28/2016 at 19:570 Comments
I started laying things out in Eagle whilst I wait for parts to arrive from Sparkfun. Mainly this has been limited to recreating what I found in the above video. Here is a rough shot without the RGB diode connected to the GPIO pins, which is an easy fix.
I also made a mockup of the device next to an Iphone 6 for size comparison. This makes me think I really need to find a way to cut down on the height of the module. I likely can cut the height to just above the Pi's USB ports. Doesn't need to be much higher than that methinks.
