Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Wireless energy Monitoring
Current monitoring of your AC power load is now possible using cross-platform I²C communications, making current monitoring possible for you
bhaskar.anil430bhaskar.anil430
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
0 comments
14 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 3
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
1.5k
0
14
10
Team (1)
  • bhaskar.anil430bhaskar.anil430
Join this project's team
  • Current monitoring
  • High accuracy energy monitoring
completed project
hardware
energy monitoring current monitoring Particle PHOTON particle electron raspberry pi arduino
Related lists
Atmel® AVR® Projects
Atmel® AVR® 8- and 32-bit MCUs deliver a unique combination of performance, power efficiency and design flexibility.
This project was created on 03/21/2016 and last updated 6 years ago.
Description
https://www.controleverything.com/products?f[0]=field_assigned_categories%3A6085&f[1]=field_assigned_categories%3A6601
this is a current monitoring board, so with this board it is possible to read current and keep a track on energy uses. it comes with a particle photon, electron and i2c adapter. so it can be used with Pi, arduino or with any other master controller. Solid Core Current Sensors with 5% Max Error Rate.
Exceeding 70 Amps through the core sensor may damage the on-board CPU. For best accuracy, its highly recommend choosing a controller with the lowest possible amperage rating required for your application. This device is designed for AC current measurement only and cannot be used to monitor DC loads. This device is typically more accurate than commercially available clamp meters and nearly as accurate as most direct w
Files
_1C_Current_Monitoring.ino
arduino code for current monitoring
ino - 831.00 bytes - 03/22/2016 at 15:46
Download
Components
  • 1 × solid core current sensor
  • 1 × atmega32 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × photon
Build Instructions
Collapse
  • 1
    Step 1
    Datasheet of current product
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
With ATmega1284p Control Seven Holding Solenoids, Measure Rotation Events from a Flow Meter and Four Current Loop Sensors.
Project Owner Contributor
Irrigate7 - m1284p Board for Holding Solenoids
ronald.sutherlandronald.sutherland
An Advanced BMS for 3-12 cells with all of the features I could cram in!
RTBMS
RoryRory
A small breadboard friendly breakout for 4 current limited LEDS
Low Current 4xLED Board
Dave's Dev LabDave's Dev Lab
A 6.4A-2uA current/voltage/power monitor based on the TI INA209 with dedicated GND usable as Shield, Wing, Breakout or Breadboard.
Watt-A-Live INA209 Power Monitor Shield Wing
MagicWolfiMagicWolfi
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "Wireless energy Monitoring ", please tell us the reason.
Send message
Remove Member
