Running in Digispark
A project log for F.P.S: Foot Presto Switch
Pedal Switch for playing FPS games
danjovicdanjovic 03/23/2016 at 00:410 Comments
The first tests have been performed using the #SILSpark board which has no pulldowns or pullups in pin 1 (PB1), but when using digispark it is necessary to change the pin connections:
#define _Pin_Left_footswitch    5
#define _Pin_Middle_footswitch  2
#define _Pin_Right_footswitch   0
Then the connections shall be like this:
