Building a Single-Switch spinoff version
A project log for F.P.S: Foot Presto Switch
Pedal Switch for playing FPS games
danjovicdanjovic 03/23/2016 at 02:510 Comments
As mentioned in previous log I have built a spinoff version of the project. Here are the details:
Only 3 components were used to built the unit (besides the footswitch itself as well as the USB cable).
The plastic flanges were trimmed and a hole was made for the P10 jack
Then another hole was made on the opposite side of the box for the USB connector. The board was attached to the bottom cover of the box using two threaded screws.
The plastic spacers were trimmed to match the height of the board with the window for the USB connector.
The Jack was then wired to the board. Since the switch is Normally Closed a bridge wire was used to keep the wires short circuited when the plug is not inserted.
The firmware was then uploaded and the pedal was tested using a web application from Microsoft from a page about keyboard ghosting (very interesting by the way).
A short video is shown here
