Building a High Quality Vacuum Table ~ TL Video!
Been struggling of late with an adequate work piece mounting for my CNC machine. Decided a vacuum bed was the only way forward!
Please see my video for all information on this project.
Have since changed to a 3mm gasket and what a change thats made!
Thanks Jack!!
https://www.youtube.com/watch?v=qXRLLjV3IEQ
Dexter wrote 04/13/2016 at 18:43 point
Hi, I'm also planning to build a vacuum table for my CNC router but probably out of high density MDF due to budget. Do you have dimensions or drawings? More specifically I was looking for dimensions of the channels and the size of gasket tubing (are you using EDPM cord?). Thanks for sharing!
Jack Black wrote 04/13/2016 at 19:04 point
Yes certainly I used a 3mm channel and a 3mm gasket which turned out to be best. I tried it also with a 2mm and 4mm as it compresses but the 3mm was perfect. I know people have had mixed results with MDF but I would recommend saving up and doing it with a high grade aluminium such as C250. We could also make you one out of MDF if that's easier, but I'll hapilly draw you something up if you need it.
Jack Black wrote 04/13/2016 at 16:22 point
Can you use a VPN?
Ivan Stepaniuk wrote 04/13/2016 at 10:08 point
:-(  In Youtube from Germany:  "Unfortunately, this video
is not available in your country because it could contain music from
UMG, for which we could not agree on conditions of use with GEMA."
