Minor Refactoring
A project log for Beehive Monitoring, Now With WiFi
Using a WeMos ESP8266 D1 Mini and DHT22 Shield to monitor beehive temperature and humidity
don-r-crenshawDon R-Crenshaw • 04/02/2016 at 20:55•0 Comments
Did a little hygienic work to clean up the code, prep for monitoring battery voltage, and get credentials out of github. The only remaining branch is the master.
