Doh! You can power the WeMos D1 Mini ESP8266 from the 5 Volt pin
A project log for Beehive Monitoring, Now With WiFi
Using a WeMos ESP8266 D1 Mini and DHT22 Shield to monitor beehive temperature and humidity
don-r-crenshawDon R-Crenshaw • 04/22/2016 at 18:18•1 Comment
Stupid of me not to realize that initially. I slapped a 7805 voltage regulator and a 9 volt battery on it and threw it out in the backyard. It works, nuff said. 7805 is an inefficient power sucker so I need to get serious now about power management.
Szabó István wrote 09/14/2019 at 11:49 • point
I find the simplest way to use a battery shield
