EMP Generator
45V chinese magnetic field generator
Chinese circuit who emit a magnetic field causing interference to electronics. There is no really an usefull way to use to this circuit, maybe just to demonstrate the principe of magnetic field and the classic fluorescent lamp demo who can be lighted without wiring. overall alll it will do is damage your electronics. Github can be found here: <a href="https://github.com/Xyl2k/EMP-Generators" target="_blank">https://github.com/Xyl2k/EMP-Generators</a> DON&apos;T USE THIS DEVICE NEARBY ANY MEDICAL EQUIPMENT LIKE PACEMAKERS ETC.
I was browsing Aliexpress while i've saw this EMP generator article:
And how it is advertised:
What a nice way to annoy hams :)
When i received the package, i noticed that they removed the transistor info.
Oh common... you can use a 2SC2078, 2SC2166, 2SC2312, 2SC1972, 2SC1972, 2SC1921, 2SC1969, 2SC1945, any of those should be fine, circuit is very primitive.
Here is a close view of the PCB:
Back of the board:
There is almost nothing there, 4 resistors, 3 capas, one npn with erased reference...
Does this worth 18$ ?
Definitely not, and everything can be made from scrap parts...
Small coil and big coil:
Want really to DIY it ? ok here is a reconstruction.
Redraw of the PCB with Eagle:
Draw of a 3D model with SolidWorks to print a case:
Board is 22.90x42.00
Assembling the 45V batteries rig, voltage must be over 30v-45v max, be careful to don't hurt yourself.
3D Printed case result:
Assembling:
Do not hold switch, just click !
Note: Aliexpress take down regularly theses kinds of products.
Does it worth to buy one ?
No, don't, make it yourself.
Another example here on eBay, theses generators are ridiculously overpriced:
There is also tons of fake youtube videos about theses.
Some others fun EMP circuit can be found on my Github, they do the same things.
base.stl
3D design
sla - 29.09 kB - 03/22/2016 at 17:51
Download
top.stl
3D design
sla - 19.91 kB - 03/22/2016 at 17:50
Download
pcb.brd
Board design
brd - 58.89 kB - 03/22/2016 at 17:50
Download
  • 5 × Nine-volt battery In PP3 size
  • 4 × 15k 5% resistors
  • 3 × 68 pF capacitors
  • 1 × LED Fiber Optics / Emitters
  • 1 × 2SC2078 Discrete Semiconductors / Power Transistors and MOSFETs
View all 9 components
  • Debunking
    Xylitol • 03/31/2024 at 17:36 • 0 comments
    If you are French or understand french, Deus Ex Silicium just published a Youtube video about theses  EMP Generators.
    I would suggest you to have a look.
  • EMP Generators and slot machines
    Xylitol • 09/25/2016 at 10:07 • 0 comments
    Just a small post to clear things related to all these urban legends and project comments.
    An EMP generator would not 'increase' money when used near a slot/vending machine, it would just cause the machine to fuck up and die not to start adding money.
    Vending machines / slots machines dont fail open otherwise you would just be able to unplug them and snacks would fall out.
    Magnetic locks and physical dispensers are used to put out money, an EMP would cause failure of the electronics roughly the same as a power outage.
    Additionally, solutions like this are used on modern machines: http://web.archive.org/web/20140225014135/http://www.defendertris.com/ENG/index-en.html
    The effects of an EMP on consumer electronics can be found here: http://www.dtic.mil/dtic/tr/fulltext/u2/a210505.pdf
    Related to the "Multifrequency EMP Generator" sold on marketplaces such as eBay or AliExpress they are all bullshit, their antenna is optimized for a single frequency, attempting to get multiple frequencies with that is like trying to talk to a space station with your garage door opener.
    If you looks for hacking this kind of materials, just get a bus pirate from sparkfun and start to analysis trames, simple as that.
View all 2 project logs
  • 1
    Step 1
    See Files for designs and Components for elements.
View all instructions
harrold wrote 12/30/2022 at 00:41 • point
Hey @Xylitol, I'm interested on how would you increase the power of the EMP this devices generates?
Would you use different transistors? Or increase the voltage (e.g add more batteries in series)?
Julio jones wrote 03/31/2020 at 06:14 • point
need one how can I get it
Drew X wrote 03/04/2019 at 07:30 • point
Hi
How do I charge the device without overshooting battery. It's reading 36V. It's an EMP NO.25 with 1 charger hole.
Jay wrote 08/25/2019 at 16:13 • point
hwy what up bro...where did u get ur No.25 from??? N does it work...if so on what machines??
jaymomaina wrote 01/10/2018 at 08:47 • point
hi I have made and tested emp jammer on slot gaming machines and it works perfectly
badr_errouani wrote 12/06/2019 at 20:47 • point
does the Emp jammer realy works on fruit machines
David H Haffner Sr wrote 09/23/2016 at 12:49 • point
This is a very clever and funny sort of device... I love it!
John k wrote 09/21/2016 at 23:42 • point
I wonder what would happen if you tested this near a slot machine??
Xylitol wrote 09/25/2016 at 09:51 • point
an EMP would just cause the machine to fuck up and die not to start adding money contrary to all these urban legends.
Steven Gann wrote 10/06/2016 at 03:42 • point
No way. My cousin knows a guy who was at a casino once and overheard a card player talk about a guy who used an EMP to trigger jackpots.
Xylitol wrote 10/06/2016 at 07:54 • point
"and overheard a card player talk about a guy"
urban legend, see https://hackaday.io/project/10464-emp-generator/log/46114-emp-generators-and-slot-machines
mjelid2011 wrote 07/30/2016 at 16:35 • point
Hi, would it be ok if i will use a transistor C2073 for 27 volts?
lantramnamcodon wrote 07/03/2016 at 11:26 • point
emp is electromagnetic pulse and if it could make the tube lamp emitted so it's must have the frequency is near micro wave and i wonder is it would danger for the health?
Xylitol wrote 07/04/2016 at 12:00 • point
magnetron ≠ emp generator
lantramnamcodon wrote 07/05/2016 at 01:43 • point
i said it's same frequency,not it's the magnetron!and you will see the it's would not good for the health.
Xylitol wrote 05/10/2016 at 16:45 • point
cellphone/gps jammer ≠ emp generator
Ghost wrote 05/10/2016 at 16:46 • point
you right that's why I'm con
Ghost wrote 05/10/2016 at 16:34 • point
I'm from USA end regulations said all jammers so illegal also Emp generator. That's why I'm confused because this device don't destroy and blocked anything
Ghost wrote 05/10/2016 at 16:06 • point
regulators said any jammer and Emp generator it's illegal.
Xylitol wrote 05/10/2016 at 16:32 • point
could you paste me a link about the law statement who said that?
Ghost wrote 05/09/2016 at 23:52 • point
this device it's legal ?
Xylitol wrote 05/10/2016 at 15:09 • point
check by yourself your country regulations concerning electromagnetic radiation but this should be OK everywhere.
This device generate a really lame field so i would be highly surprised if anyone would care.
of course after if you use it to destruct objects who's not your property etc.. you will have problems. (but that just common sense, it's like having a knife, it's ok to have one but depend of the usage you do)
