1Read the legal notes!
Read the legal notes and check with country's law, if you are eligible to run the code
2Download code
Download code from project's repository on github
3Build and upload code
1. Download PlatformIO and install it with your preferred IDE for development and building code.
2. If you want to use LoRaWAN network, create /src/loraconf.h from /src/loraconf.sample.h and insert your personal network access keys.
3. Compile code with PlatformIO. Dependencies will automatically install.
4. Upload code to ESP32 board.
4Go testing
Pick a battery, connect it to your ESP32 device and go pax counting.
5Contribute!
Contribute to project by enhancing and testing the code on github
Verkehrsrot
