Second compute node operational again
A project log for Solar-powered cloud computing
Building a private cloud from scratch using low-power equipment
Stuart LonglandStuart Longland 07/18/2019 at 01:350 Comments
So, a few months back I had the failure of one of my storage nodes. Since I need 3 storage nodes to operate, but can get away with a single compute node, I did a board-shuffle. I just evacuated lithium of all its virtual machines, slapped the SSD, HDD and cover from hydrogen in/on it, and it became the new storage node.
Actually I took the opportunity to upgrade to 2TB HDDs at the same time, as well as adding two new storage nodes (Intel NUCs). I then ordered a new motherboard to get lithium back up again. Again, there was an opportunity to upgrade, so ~$1500 later I ordered a SuperMicro A2SDi-16C-HLN4F. 16 cores, and full-size DDR4 DIMMs, so much easier to get bits for. It also takes M.2 SATA.
The new board arrived a few weeks ago, but I was heavily snowed under with activities surrounding Brisbane Area WICEN Group and their efforts to assist the Stirling’s Crossing Endurance Club running the Tom Quilty 2019. So it got shoved to the side with the RAM I had purchased to be dealt with another day.
I found time on Monday to assemble the hardware, then had fun and games with the UEFI firmware on this board. Put simply, the legacy BIOS support on this board is totally and utterly broken. The UEFI shell is also riddled with bugs (e.g. ifconfig help describes how to bring up an interface via DHCP or statically, but doing so fails). And of course, PXE is not PXE when UEFI is involved.
I ended up using Ubuntu’s GRUB binary and netboot image to boot-strap the machine, after which I could copy my Gentoo install back in. I now have the machine back in the rack, and whilst I haven’t deployed any VMs to it yet, I will do so soon. I did however, give it a burn-in test updating the kernel:
  LD [M]  security/keys/encrypted-keys/encrypted-keys.ko  MKPIGGY arch/x86/boot/compressed/piggy.S  AS      arch/x86/boot/compressed/piggy.o  LD      arch/x86/boot/compressed/vmlinux
ld: arch/x86/boot/compressed/head_64.o: warning: relocation in read-only section `.head.text'
ld: warning: creating a DT_TEXTREL in object.  ZOFFSET arch/x86/boot/zoffset.h  OBJCOPY arch/x86/boot/vmlinux.bin  AS      arch/x86/boot/header.o  LD      arch/x86/boot/setup.elf  OBJCOPY arch/x86/boot/setup.bin  BUILD   arch/x86/boot/bzImage
Setup is 16444 bytes (padded to 16896 bytes).
System is 6273 kB
CRC ca5d7cb3
Kernel: arch/x86/boot/bzImage is ready  (#1)
real    7m7.727s
user    62m6.396s
sys     5m8.970s
lithium /usr/src/linux-stable # git describe
v5.1.11
7m for make -j 17 to build a current Linux kernel is not bad at all!
