2 days and counting on solar…
A project log for Solar-powered cloud computing
Building a private cloud from scratch using low-power equipment
Stuart LonglandStuart Longland 12/25/2017 at 02:290 Comments
So, I'm home now for the Christmas break… and the fan in my power supply decided it would take a Christmas break itself.
The power supply was purchased brand new in June… it still works as a power supply, but with the fan seized up, it represents an overheating risk.  Unfortunately, the only real options I have are the Xantrex charger, which cooked my last batteries, or a 12V 20A linear PSU I normally use for my radio station.  20A is just a touch light-on, given the DC-DC converter draws 25A.  It'll be fine to provide a top-up, but I wouldn't want to use it for charging up flat batteries.
Now, I can replace the faulty fan.  However, that PSU is under warranty still, so I figure, back it goes!
In the meantime, an experiment.  What happens if I just turn the mains off and rely on the batteries?  Well, so far, so good.  Saturday afternoon, the batteries were fully charged, I unplugged the mains supply.  Battery voltage around 13.8V.
Sunday morning, battery was down to 12.1V, with about 1A coming in off the panels around 7AM (so 6A being drained from batteries by the cluster).
By 10AM, the solar panels were in full swing, and a good 15A was being pumped in, with the cluster drawing no more than 8A.  The batteries finished the day around 13.1V.
This morning, batteries were slightly lower at 11.9V.   Just checking now, I'm seeing over 16A flowing in from the panels, and the battery is at 13.2V.
I'm in the process of building some power meters based on NXP LPC810s and TI INA219Bs.  I'm at two minds what to use to poll them, whether I use a Raspberry Pi I have spare and buy a case, PSU and some sort of serial interface for it… or whether I purchase a small industrial PC for the job.
The Technologic Systems TS-7670 is one that I am considering, given they'll work over a wide range of voltages and temperatures, they have plenty of UARTs including RS-485 and RS-232, and while they ship with an old Linux kernel, yours truly has ported both U-Boot and the mainline Linux kernel.  Yes, it's ARMv5, but it doesn't need to be a speed demon to capture lots of data, and they work just fine for Barangaroo where they poll Modbus (via pymodbus) and M-bus (via python-mbus).
