Encoders
A project log for Nano TTY
Small serial terminal for debugging your robots
dehipudeʃhipu 04/15/2016 at 14:011 Comment
The encoders arrived today, and I actually had to take a moment to read about them to understand how they work. Those are EVQWKA quadrature encoders, with an additional button activated by pressing on the wheel -- which makes them perfect as an interface for all sorts of menus or scrolling:
You can easily google for a datasheet for these, which will give you all the dimensions and the pinout. But it doesn't say anything about the protocol used. Turns out that the protocol is so standard, that nobody even mentions it anymore in the datasheets.
Inside of them there is a star-shaped contact, and two contacts that touch the prongs of the star. When you rotate the wheel, the star rotates too, and touches the two contacts. The order in which the contacts are touched tells you the direction of rotation. That's it. This particular model has one pring per "click", so you will get 10, 00, 01, 11 on rotation one way, and 01, 00, 10, 11 on rotation the other way. You can easily detect those with the pin interrupts in Arduino, but I choose to use a library from http://www.pjrc.com/teensy/td_libs_Encoder.html
It works flawlessly. Now to program and assemble the whole thing...
Lorenzo Egli Grandi wrote 02/03/2017 at 09:01 point
Hey, nice project. Love those rotary encoders with push button embedded.
Where to purchase those?
