DIY Infrared Rework Station
Reflow station made from scrap, cheap and simple as possible.
This is my reflow station made from scrap. It uses chinese K-type dot thermocouples, opamp, optotriacs/triacs, 20x4 display and Arduino nano CH340G clone. Heating is done by old infrared bathroom heater and short 600W halogen inside 100W halogen floodlight on table lamp stand.
Options for top heater:
- Short 600W halogen made by TESLA and PHILLIPS i think,
- or Ebay ceramic heater.
Options for preheater:
- Apartment complex bathroom infrared heater - has long delay between power apply
and heating the work, so the PID needs fine tunning
- Microwawe grill system
- insert from iron or any other heating element with shape that fits
The Arduino runs two PIDs, slow ON/OFF regulator for preheating and interrupt driven phase regulator for top heater.
I use AMTECH RMA-223 flux.
GPUs repaired:
ATI:
4890
3870x2
5870
Nvidia:
260
560
560Ti
Notebooks repaired:
DELL D630 with NVS135 multifail GPU
Some HP i don't remember with GPU problem
Motherboards repaired (shi- i mean, chipset):
nothing yet
Motherboards repaired (socket):
Nothing yet, i have few 1366 to try
Adobe Portable Document Format - 2.52 MB - 11/07/2018 at 21:43
Preview
Download
Portable Network Graphics (PNG) - 686.32 kB - 11/07/2018 at 21:43
Preview
Download
plain - 12.16 kB - 11/07/2018 at 21:43
Download
mereni_ino.ino
Arduino program. Big steaming buggy mess, but it works as is.
ino - 6.57 kB - 03/25/2016 at 23:03
Download
reflow.fzz
Proto-board schematic. The machine is done on hole-grid board.
fzz - 34.56 kB - 03/25/2016 at 23:02
Download
  • 1 × arduino nano CH340G Do NOT use prolific or FTDI! It will not work
  • 1 × LM358 Any opamp will work, rail to rail will work better.
  • 1 × MOC3020 Just use that without zero crossing detection
  • 1 × TRIAC >8A >600V Any triac will work
  • 1 × 12V transformer Any will do, >500mA rating, double insulation.
View all 6 components
View project log
  • 1
    Step 1
    Only instruction is: Get the parts in scrapheap and ebay and go full Macgyver on it.
View all instructions
viscosity360 wrote 01/08/2021 at 07:51 point
20.1k views but only 15 likes???  Wow the hackaday community is a * little *  spoiled.
 This is an excellent example of a hack.  And very useful for hardware techs... even if it's been done before!   Great job!!
Jase1 wrote 02/06/2020 at 17:07 point
Hi
Is there any chance you could help me to change some of your variables in your Arduino code to english as I'm struggling to follow it.
Tomáš wrote 04/07/2016 at 15:12 point
Moc děkuji za doplňění informací. Asi se do něčeho podobného pustím. Já dělám hlavně elektroniku kopírek a plotterů, tam taková velká BGA jako GPU nejsou, ale někdy také narážím na limity horkovzduchu s podehřevem a to je pak o nervy.
RMA-223, co jsem měl, byl oproti tomu od Rusa mnohem méně smáčivý, choval se spíš jako nějaký nízkotuhnoucí vosk než gel. Honil jsem ho vzduchem po desce a ne a ne zatéct kam měl. Ten od Rusa se prostě rozleje kam se mu ukáže.
Michael Skrepsky wrote 04/07/2016 at 18:28 point
RMA-223 používám tak, že si ho z původní nádobky přetlačím do stříkačky s tryskou na luer-lock (tohle: http://www.ebay.com/itm/371105848734?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT - SMT SMD PCB Solder Paste Adhesive Glue Liquid Dispenser+Dispensing Needle 50pcs) a po ohřátí desky na podehřevu dávkuju na celou jednu stranu čipu, a sleduju jak to kapilaritou zaleze pod čip až na druhou stranu, kdy dávkování přerušim. Jak se to dostane do kontaktu s teplou deskou, tak to zateče, kam je potřeba. A s kvalitou pájení nebyly potíže?
Tomáš wrote 04/06/2016 at 19:28 point
Slušný bazmek, gratuluju! Máte na horním halogenu nějakou optiku nebo clonky, aby to svítilo a hřálo jen kam má?
Sám bych něco takového potřeboval, ale nemám to kam dát, tak používám zespodu 100w tirakem regulovanou halogenovou bodovku a shora horkovzduch. Taky to funguje, ale je to prasárna.
S RMA-223 nemám moc dobré zkušenosti, na BGA kupuju tohle http://www.ebay.com/itm/Flux-Gel-neutral-professional-soldering-industrial-and-consumer-electronic-/271177104425?hash=item3f236a3c29
a jsem s tím naprosto spokojený.
Michael Skrepsky wrote 04/07/2016 at 08:24 point
Horní halogen (svítidlo) není nijak upraven. Při výkonu do 250W se uchladí, když jsem zkoušel plných 600W, tak mi po 15min prasknul zátav halogenky. Na to pozor, chladit zátavy je při vyšších výkonech nutnost. Halogen je Tesla HPZ 600W/225V určený pro filmaře. Je v krátké patici, ve které se dělají jen 100W. Už se nevyrábí, ale existuje náhrada: http://www.heureka.cz/?h[fraze]=OSRAM+64553,+650W+230V+R7s  A občas se objeví na ebay černý  "ceramic top heater rework" za cca 300 Kč.
Jako odclonění používám alobal na kondenzátory a plastové díly, jinak není potřeba, naopak je žádoucí prohřát PCB i okolo, aby neodebíralo teplo.
Spodní ohřev infrazářičem je strašně pomalý (než se dostane teplo od spirály na povrch), proto je obtížné nastavit PID. Plynulý náběh ale nevadí, protože se to stejně musí ohřát delší dobu. Pro rychlejší regulaci se dá použít spirála v keramice z mikrovlnné trouby, holé spirály na šamotu nebo dlouhé halogeny. Při předimenzování  (>600W spirála) tím i celou desku zapájíte s krytem místo horního ohřevu.
Horkovzduchem jsem při zkouškách GPU dovedl od artefaktů k nezobrazení ničeho, a poté infrazářičem k normálnímu fungování. Horkovzduch nemá plochu ohřevu, a GPU větší, než kancelářské čipy neohřeje dostatečně ani řízeně. Nvidia GTX 4xx a 5xx naprosto bez šance i s podehřevem.
Jaké špatné zkušenosti máte s RMA-223? Děkuji za odkaz, vyzkouším to.
