DISCLAIMER AND SAFETY WARNING
THIS GUN HAS THE ABILITY TO SERIOUSLY INJURE HUMANS OR OTHER LIVING THINGS. PLEASE TAKE EXTREME CAUTION AND CARE WHEN BUILDING AND OPERATING THE GUN. POWER TOOLS ARE INVOLVED IN THE CONSTRUCTION AND HAVE THE ABILITY TO REMOVE CARELESS LIMBS. THE PRESSURE CHAMBER COULD EXPLODE RESULTING IN A SHOCK WAVE AND SHRAPNEL. MAKE SURE TO USE PRESSURE RATED PVC. THE VACUUM CHAMBER COULD IMPLODE AND ALSO CAUSE SHRAPNEL. BE SURE TO USE THICK WALLED PVC. THE GUN HAS THE ABILITY TO MISFIRE, SO KEEP ALL LIVING THINGS AWAY FROM BOTH SIDES OF THE GUN WHEN THE PRESSURE CHAMBER IS PRESSURIZED OR THERE IS A VACUUM. ALL PVC FITTINGS MUST BE BONDED USING PVC GLUE, AND THERE IS STILL A CHANCE OF THE FITTING COMING LOOSE. THE PROJECTILE CAN EXPLODE INTO SHRAPNEL IN THE EVENT OF A COLLISION WITH ANOTHER OBJECT.
PLEASE USE COMMON SENSE AND REMEMBER I AM NOT RESPONSIBLE FOR YOUR ACTIONS AND INJURIES DUE TO THIS DEVICE.
