Alternatives
A project log for Quick & Dirty Frequency Generator
Because I need it, I can and I'm cheap. So maybe I'll do.
yann-guidon-ygdesYann Guidon / YGDES 04/25/2016 at 19:467 Comments
I just discovered this chip : the STATEK PXO-1000 integrated quartz oscillator with integrated predividers.
http://pdf.datasheetarchive.com/datasheetsmain/Datasheets-8/DSA-154595.pdf
Yes it's pretty practical to hack a tiny frequency generator with a minimum part count. I ordered a few of these antiques that don't seem to grow old.
Of course "I could do this with a PIC" but the total absence of programming is worth it :-)
In the same vein, after a hint from @K.C. Lee, I got myself a bunch of PLLs.
Actually it's called a "zero-delay clock buffer" with 8 outputs but the CYPRESS CY2308SC-4 also works as a frequency doubler that can output between 10MHz and 133MHz.
By playing with the feedback signal, not only I can smooth the signal (reducing the jitter) but also bring the frequency much higher. I expect my Rb source to output 20MHz, which will be halved by the ALU, but I can reach up to 120MHz :-)
Another discovery from http://www.jmargolin.com/vgens/vgens.htm :
"The BRM used by Atari was the 7497. The 7497 is a 6-bit BRM. With a digital input of 63, it will produce 63 output pulses for every 64 input clocks. With a digital input of 1 it will produce one output pulse every 64 input clocks. Two 7497s were chained together to produce a 12-bit BRM. The data sheet for the 7497 is available here (PDF 282KB)."
So yes there is a simpler, faster (better) way to perform the frequency division.
Of course, all of this would run faster, better and take less power if I just used a A3P250.
Eric Hertz wrote 04/26/2016 at 07:44 point
wow, never seen a chip looking like that.
Yann Guidon / YGDES wrote 04/26/2016 at 07:49 point
Neither did I.
Instant buy (after consulting online resources).
The DS32KHZ and DS3231 seem to be derived from this hybrid approach, maybe STATEK got bought by Dallas ?
K.C. Lee wrote 04/25/2016 at 20:31 point
You can also add an external divider on the feedback path to do a higher multiplier ratio in a single stage.  You can use a loadable counter to implement divide by n.
http://www.cypress.com/file/38066/download    figure 13
There are limitations on cascading multiple PLL as it will increase jitters at each stage.
http://www.eetimes.com/document.asp?doc_id=1225577
Yann Guidon / YGDES wrote 04/25/2016 at 20:38 point
I don't think the CY2308SC has an externally accessible feedback path... Did I overlook something in the datasheet ?
K.C. Lee wrote 04/25/2016 at 21:07 point
16         FBK PLL feedback input
The soic-8 CY2305 has an internal feedback.
Yann Guidon / YGDES wrote 04/26/2016 at 08:00 point
Daaaaaamn again, you're right... I'll have to examine this. Soon. But now I have to find very high speed predividers...
Yann Guidon / YGDES wrote 04/27/2016 at 05:04 point
Reading further, I see that the CY2308's REF input is 5V tolerant.
Awesome!
