Writing an Assembler in Python
A project log for muCPU: an 8-bit MCU
An 8-bit load-store CPU with 2 pipeline stages, designed in Logisim and implemented in VHDL + assembler written in Python
reed-fosterReed Foster 04/16/2016 at 03:370 Comments
As I was writing some simple test code to run on my processor testbench (in iSim), I found that it was tedious and slow to write hex instructions from assembly mnemonics. What better solution to a problem that is tedious than a program that does the hex encoding over and over. I wrote a simple application in Python (because of its simple, powerful string manipulation functions) to "assemble" very rudimentary assembly language instructions. Screenshots and code below.
Input:
Output:
0 => x"84b0",
1 => x"83b0",
2 => x"2142",
3 => x"5008",
4 => x"c1fc",
5 => x"40f8",
6 => x"0b21",
7 => x"0000",
8 => x"40fe",
Code:
from Tkinter import *
import re
from tkFileDialog import *
import os.path
import sys
filename = "Untitled"
fileexists = False
def asmtoint(asm):
    asm_split = re.split(" |, |\(|\)", asm)
    args = []
    for i in range (len(asm_split)):
        if (asm_split[i] != ""):
            args.append(asm_split[i])
    #print args
    opcode = 0
    func = 0
    rd = 0
    rs = 0
    rt = 0
    imm = 0
    if (args[0] == "sll"):
        if (len(args) != 4):
            return 0,0,0,0,0,0
        opcode = 0
        func = 0
        rd = int(args[1][1:])
        rs = int(args[2][1:])
        rt = int(args[3][1:])
    elif (args[0] == "add"):
            return 0,0,0,0,0,0
        opcode = 0
        func = 1
    elif (args[0] == "sub"):
            return 0,0,0,0,0,0
        opcode = 0
        func = 2
    elif (args[0] == "nand"):
            return 0,0,0,0,0,0
        opcode = 0
        func = 3
    elif (args[0] == "nor"):
            return 0,0,0,0,0,0
        opcode = 0
        func = 4
    elif (args[0] == "bez"):
        if (len(args) != 3):
            return 0,0,0,0,0,0
        opcode = 1
        rt = 0
        rs = int(args[1][1:])
        imm = int(args[2])
    elif (args[0] == "bnez"):
            return 0,0,0,0,0,0
        opcode = 1
        rt = 1
        imm = int(args[2])
    elif (args[0] == "bgez"):
            return 0,0,0,0,0,0
        opcode = 1
        rt = 2
        imm = int(args[2])
    elif (args[0] == "blez"):
            return 0,0,0,0,0,0
        opcode = 1
        rt = 3
        imm = int(args[2])
    elif (args[0] == "bgz"):
            return 0,0,0,0,0,0
        opcode = 1
        rt = 4
        imm = int(args[2])
    elif (args[0] == "blz"):
            return 0
        opcode = 1
        rt = 5
        imm = int(args[2])
    elif (args[0] == "lw"):
        if (args[-1] == ''):
            args = args[0:-1]
        if (len(args) != 3 and len(args) != 4):
            return 0,0,0,0,0,0
        opcode = 2
        rt = int(args[1][1:])
        if (len(args) == 3):
            imm = 0
        else:
            imm = int(args[2])
            rs = int(args[3][1:])
    elif (args[0] == "sw"):
            args = args[0:-1]
            return 0,0,0,0,0,0
        opcode = 3
            imm = 0
        else:
            imm = int(args[2])
    else:
        return 0,0,0,0,0,0
    return opcode, rs, rt, rd, func, imm
def inttohex(opcode, rs, rt, rd, func, imm):
    if (opcode == 0):
        opstr = format(opcode, '02b')
        rsstr = format(rs, '03b')
        rtstr = format(rt, '03b')
        rdstr = format(rd, '03b')
        fnstr = format(func, '05b')
        #print opstr, rsstr, rtstr, rdstr, fnstr
        instruction = opstr + rsstr + rtstr + rdstr + fnstr
    else :
        if (imm < 0):
            imm2s = ((-imm) ^ 255) + 1
            immstr = format(imm2s, '08b')
        else :
            immstr = format(imm, '08b')
        #print opstr, rtstr, rsstr, immstr
        instruction = opstr + rsstr + rtstr + immstr
    return format(int(instruction, 2), '04x')
def decode(asm):
    opcode, rs, rt, rd, func, imm = asmtoint(asm)
    instruction = inttohex(opcode, rs, rt, rd, func, imm)
    return instruction
def openFile():
    global filename
    openfilename = askopenfilename()
    if openfilename is not None:
        filename = openfilename
        asmfile = open(filename, "r")
        asmfile.seek(0)
        asmdata = asmfile.read()
        textArea.delete("1.0", "end - 1c")
        textArea.insert("1.0", asmdata)
        asmfile.close()
        filemenu.entryconfig(filemenu.index("Save"), state = NORMAL)
        frame.title("muCPU Assembler [" + filename + "]")
        frame.focus()
def saveFile():
    global filename
    asmdata = textArea.get("1.0", "end - 1c")
    asmfile = open(filename, "w")
    asmfile.seek(0)
    asmfile.truncate()
    asmfile.write(asmdata)
    asmfile.close()
def saveFileAs():
    global filename
    global fileexists
    saveasfilename = asksaveasfilename()
    if saveasfilename is not None:
        filename = saveasfilename
        fileexists = True
        asmfile.seek(0)
        asmfile.truncate()
        asmfile.close()
        frame.focus()
def exitApp():
    frame.destroy()
    sys.exit()
def compileASM():
    global filename
    cpu_out = ""
    asm_in = textArea.get("1.0", END)
    asmlines = re.split("\n", asm_in)
    for i in range (len(asmlines)):
        if (asmlines[i] != ""):
            #print asmlines[i]
            cpu_out += str(i) + " => x\"" + decode(asmlines[i]) + "\",\n"
    #print cpu_out
    name, ext = os.path.splitext(filename)
    hexfilename = name + ".hex"
    hexfile = open(hexfilename, "w")
    hexfile.seek(0)
    hexfile.truncate()
    hexfile.write(cpu_out)
    hexfile.close()
Tk().withdraw()
frame = Toplevel()
scrollbar = Scrollbar(frame)
scrollbar.pack(side = RIGHT, fill = Y)
textArea = Text(frame, height = 30, width = 100, padx = 3, pady = 3, yscrollcommand = scrollbar.set)
textArea.pack(side=RIGHT)
scrollbar.config(command=textArea.yview)
menubar = Menu(frame)
filemenu = Menu(menubar, tearoff=0)
filemenu.add_command(label="Open", command=openFile)
filemenu.add_command(label="Save", command=saveFile, state = DISABLED)
filemenu.add_command(label="Save as...", command=saveFileAs)
filemenu.add_command(label="Exit", command=exitApp)
menubar.add_cascade(label="File", menu=filemenu)
runmenu = Menu(menubar, tearoff=0)
runmenu.add_command(label="Compile", command=compileASM)
menubar.add_cascade(label="Run", menu=runmenu)
frame.config(menu=menubar)
frame.minsize(750, 450)
frame.maxsize(750, 450)
frame.mainloop()
#Sample counting loop code
lw r4, 176(r0)
lw r3, 177(r0)
sub r2, r4, r1
bez r2, 8
sw r1, 252(r0)
bez r0, -8
add r1, r1, r3
sll r0, r0, r0
bez r0, -2
