Potential Signs of Life
A project log for muCPU: an 8-bit MCU
An 8-bit load-store CPU with 2 pipeline stages, designed in Logisim and implemented in VHDL + assembler written in Python
Reed FosterReed Foster 05/14/2016 at 23:480 Comments
I wrote some vhdl to connect the core module to my spi module that I created, as well as some assembly code. Looking at the simulation waveform, the display should theoretically display a blank screen, but that was not the case. The clock and data are slow enough according to the ssd1306 spec sheet, but I'll try a slower clock later (the whole spi controller runs off of the divided clock, so slowing the sclk will introduce problems with the fifo which will require some redesign, otherwise I would have already done it). Even though it is far from working, it's still exciting to see pixels light up on the display. As usual, commentless :( vhdl code is up on github.
(side note: I have tested the display with an arduino, and it does work).
Picture of the display
SPI waveform
