With an almost complete loss of data between the SPI controller and the SSD1306, I decided that I should use just the processor core because I know that at least the processor core runs how it is supposed to (how the simulation runs) on the FPGA itself. With software SPI, I ran into a whole new set of problems. With an 8 bit immediate width, branch instructions cannot cover very much code. Furthermore, a loop that executes 256 times is not possible, so one cycle of the loop must be unfolded. By controlling the io ports with software and unfolding a loop, my code space had grown so large that the outer loop (I have 3 nested loops) was so wide I could not branch from end to end. The solution: add intermediate branches. Pseudo-code:
jmp 2; skips next two instructions when loop is executed ; they are only executed when branched/jumped to from ; elsewhere in the program jmp outerloop_start; intermediate for backwards jump jmp outerloop_exit; intermediate for exit branch
When I was using the vhdl SPI controller, one of the clear indicators that the SSD1306 wasn't receiving all of the data was the dimness of the screen. I did a couple tests with an arduino, and when I disabled the charge-pump configurations, the display was unlit connected to 3.3v and only very dim with 5v. I have yet to figure out why the display was able to receive some commands and not others, but I eventually will troubleshoot that with a logic analyzer or something like that.
Using this indicator, I was able to tell whether or not the software SPI worked fairly easily. Unfortunately, it took me forever to figure out what was going wrong after the initialization; there wasn't any comprehensible data that appeared on the display. I tested a pattern of bytes that I expected would fill the top row only, but found a much different result; the 16 bytes that I sent were arranged vertically.
After discovering this, I looked at the datasheet for the SSD1306 and discovered that I simply misunderstood how the device was interpreting the data I sent it. After visiting stackexchange for a couple conversion methods between hex and binary strings in python, I produced a simple program that remaps the bits in the .xbm file format (the one that I had been using to draw and save black and white images) to bits that can be sent, byte by byte, to the SSD1306 without additional processing on the FPGA. The end result:
Zoomed in (I augmented my phone camera with a small lens from an ancient video camera). Individual pixels are visible.
Assembler code:
//PortD pin assignments (nc means no connection) //assignment set-bitmask (or) reset-bitmask (and) //pin0 => mosi 00000001 | 1 11111110 | 254 //pin1 => sclk 00000010 | 2 11111101 | 253 //pin2 => dc 00000100 | 4 11111011 | 251 //pin3 => rst 00001000 | 8 11110111 | 247 //pin4 => ss 00010000 | 16 11101111 | 239 // //SET RST and SS (rst, ss = 1) li r7, 255 //set par (page address register) to io bank li r2, 24 //bit mask for rst (high) lb r1, 255(r0)//load spi reg or r1, r1, r2 //apply bit mask sb r1, 255(r0)//store spi reg //RESET RST (rst = 0) li r2, 247 //bit mask for rst (low) lb r1, 255(r0)//load spi reg and r1, r1, r2//apply bit mask sb r1, 255(r0)//store spi reg // DELAY LOOP (loops for ~4us to hold reset low for length required by ssd1306) // while (true) { // if (i = 10) {break;} // else {i++}; // } li r4, 10 //r4 is stopval li r3, 1 //r3 is incrementval li r1, 0 //r1 is counting reg delay_start: sub r2, r4, r1 //r2 compares r4 and r1; if neg, then r1 > r4; if zero, r1 = r4 bez r2, delay_exit//if r2==0, then exit loop nop //delay slot bez r0, delay_start//infinite backwards loop add r1, r1, r3 //increment r1 by r3 //SET RST (rst = 1) delay_exit: li r2, 8 //bit mask for rst (high) lb r1, 255(r0)//load spi reg or r1, r1, r2 //apply bit mask sb r1, 255(r0)//store spi reg //RESET D/C (d/c = 0; put ssd1306 into command mode, which it should already be in) li r2, 251 //bit mask for d/c lb r1, 255(r0)//load spi reg and r1, r1, r2//apply bit mask sb r1, 255(r0)//store spi reg //COMMAND LOOP (sends 25 init commands + 6 memory config commands; prepare ssd1306 for buffwrite) // while (true) { // if (i = 31) {break;} // else { // ss = 0 // while (true) { // if (j = 8) {break;} // else { // sclk = 0; // mosi = byte[j]; // sclk = 1; // } // } // ss = 1; // } //loop setup li r1, 0 //r1 is counting reg li r3, 1 //r3 is incrementval cmdloop_start: li r4, 31 //r4 is stopval sub r2, r4, r1//r2 compares r4 and r1; if neg, then r1 > r4; if zero, r1 = r4 bez r2, cmdloop_exit//if r2==0, then exit loop //loop contents li r7, 12 //set par to rom[commands] lb r6, 0(r1) //r6 holds the byte to be send via spi li r7, 255 //set par back to io bank //reset ss li r5, 239 //bit mask to reset ss lb r4, 255(r0)//load spi reg and r4, r5, r4//apply bit mask sb r4, 255(r0)//store spi reg //send byte (loop) li r2, 0 //r2 is counting reg cmdbyte_start: li r4, 8 //r4 is stopval sub r5, r4, r2//r5 compares r4 and r2; if neg, then r2 > r4; if zero, r2 = r4 bez r5, cmdbyte_exit//exit loop if r5==0 nop //delay slot //sclk low (setup mosi) li r5, 253 //bit mask to reset sclk lb r4, 255(r0)//load spi reg and r4, r5, r4//apply bit mask sb r4, 255(r0)//store spi reg //mosi //shift left unit desired bit is msb, then shift right 7; b7:b1=0, b0=desired bit sll r5, r6, r2//shift current bit to msb li r4, 7 //shamt for srl srl r5, r5, r4//shift msb to lsb lb r4, 255(r0)//load spi reg li r3, 254 //bitmask to reset mosi and r4, r4, r3//clear mosi bit of spi reg or r4, r5, r4 //combine spi reg with mosi_out sb r4, 255(r0)//store spi reg //sclk high (latch mosi) li r5, 2 //bit mask to set sclk lb r4, 255(r0)//load spi reg or r4, r5, r4 //appy bit mask sb r4, 255(r0)//store spi reg //end loop li r3, 1 //reset constant loop variables; r4 (stopval) reset later bez r0, cmdbyte_start//infinite backwards loop add r2, r2, r3//increment r2 by r3 //set ss cmdbyte_exit: li r5, 16 //bit mask to set ss lb r4, 255(r0)//load spi reg or r4, r5, r4 //appy bit mask sb r4, 255(r0)//store spi reg //end loop li r3, 1 //reset constant loop variables; r4 (stopval) reset later bez r0, cmdloop_start//infinite backwards loop add r1, r1, r3//increment r1 by r3 //SET D/C (d/c = 1; put ssd1306 into data mode) cmdloop_exit: li r7, 255 //set par to io bank li r2, 4 //bit mask for d/c lb r1, 255(r0)//load spi reg or r1, r1, r2 //apply bit mask sb r1, 255(r0)//store spi reg //DATA LOOP (sends 1024 bytes of data to gddram in ssd1306 // // i = 0; // while (true) { // r7 = i; // r6 = mem(0); // k = 0; // cs = 0; // while (true) { // sclk = 0; // mosi = r6(k); // sclk = 1; // k++; // if (k == 8) {break;} // } // cs = 1; // j = 1; // while (true) { // cs = 0; // k = 0; // while (true) { // sclk = 0; // mosi = r6(k); // sclk = 1; // k++; // if (k == 8) {break;} // } // cs = 1; // j++; // if (j == 0) {break;} // } // i++; // if (i == 12) {break;} // } li r7, 8 //set par to rom[data] li r1, 8 //r1 is counting reg (initialized to same value as par) li r4, 1 //r4 is countval outloop_start: li r5, 12 //r5 is stopval sub r6, r5, r1//r6 compares r5 and r1; if neg, then r1 > r5; if zero, r1 = r5 bez r6, itrfwd//exit loop if stopval is reached nop //delay slot //r6 = byte to send li r2, 0 //bleh add r7, r1, r0//set par to rom[data] lb r6, 0(r2) //r6 holds the byte to be send via spi li r7, 255 //set par back to io bank //reset ss li r5, 239 //bit mask to reset ss lb r4, 255(r0)//load spi reg and r4, r5, r4//apply bit mask sb r4, 255(r0)//store spi reg //send byte (loop) li r3, 0 //r3 is counting reg dbyte_start: li r5, 8 //r5 is stopval sub r4, r5, r3//r6 compares r5 and r3; if neg, then r3 > r5; if zero, r3 = r5 bez r4, dbyte_exit//exit loop if r5==0 nop //delay slot //sclk low (setup mosi) li r5, 253 //bit mask to reset sclk lb r4, 255(r0)//load spi reg and r4, r5, r4//apply bit mask sb r4, 255(r0)//store spi reg //mosi //shift left unit desired bit is msb, then shift right 7; b7:b1=0, b0=desired bit sll r5, r6, r3//shift current bit to msb li r4, 7 //shamt for srl srl r5, r5, r4//shift msb to lsb lb r4, 255(r0)//load spi reg li r7, 254 //bitmask to reset mosi and r4, r4, r7//clear mosi bit of spi reg or r4, r5, r4 //combine spi reg with mosi_out li r7, 255 //set par to io bank sb r4, 255(r0)//store spi reg //sclk high (latch mosi) li r5, 2 //bit mask to set sclk lb r4, 255(r0)//load spi reg or r4, r5, r4 //appy bit mask sb r4, 255(r0)//store spi reg //end loop li r4, 1 //reset constant loop variables; r5 (stopval) reset later bez r0, dbyte_start//infinite backwards loop add r3, r3, r4//increment r3 by r4 //set ss dbyte_exit: li r5, 16 //bit mask to set ss lb r4, 255(r0)//load spi reg or r4, r5, r4 //appy bit mask sb r4, 255(r0)//store spi reg bez r0, 10 //skip intermediate branches, they are only executed when outer loop is repeated/exited nop itrback: bez r0, outloop_start //jump to start of outer loop nop itrfwd: bez r0, outloop_exit //jump to end of outer loop nop //inner loop li r2, 1 //r2 is countval inloop_start: bez r2, inloop_exit//exit loop if r2 overflowed //loop contents add r7, r1, r0//set par to rom[data] lb r6, 0(r2) //r6 holds the byte to be send via spi li r7, 255 //set par back to io bank //reset ss li r5, 239 //bit mask to reset ss lb r4, 255(r0)//load spi reg and r4, r5, r4//apply bit mask sb r4, 255(r0)//store spi reg //send byte (loop) li r3, 0 //r3 is counting reg lp_dbyte_start: li r5, 8 //r5 is stopval sub r4, r5, r3//r6 compares r5 and r3; if neg, then r3 > r5; if zero, r3 = r5 bez r4, lp_dbyte_exit//exit loop if r5==0 nop //delay slot //sclk low (setup mosi) #loopstart li r5, 253 //bit mask to reset sclk lb r4, 255(r0)//load spi reg and r4, r5, r4//apply bit mask sb r4, 255(r0)//store spi reg //mosi //shift left unit desired bit is msb, then shift right 7; b7:b1=0, b0=desired bit sll r5, r6, r3//shift current bit to msb li r4, 7 //shamt for srl srl r5, r5, r4//shift msb to lsb lb r4, 255(r0)//load spi reg li r7, 254 //bitmask to reset mosi and r4, r4, r7//clear mosi bit of spi reg or r4, r5, r4 //combine spi reg with mosi_out li r7, 255 //set par to io bank sb r4, 255(r0)//store spi reg //sclk high (latch mosi) li r5, 2 //bit mask to set sclk lb r4, 255(r0)//load spi reg or r4, r5, r4 //appy bit mask sb r4, 255(r0)//store spi reg //end loop #loopend li r4, 1 //reset constant loop variables; r5 (stopval) reset later bez r0, lp_dbyte_start//infinite backwards loop add r3, r3, r4//increment r3 by r4 //set ss lp_dbyte_exit: li r5, 16 //bit mask to set ss lb r4, 255(r0)//load spi reg or r4, r5, r4 //appy bit mask sb r4, 255(r0)//store spi reg //end loop li r4, 1 //reset constant loop variables; r5 (stopval) reset later bez r0, inloop_start//infinite backwards loop add r2, r2, r4//increment r2 by r4 //end loop inloop_exit: li r4, 1 //reset constant loop variables; r5 (stopval) reset later bez r0, itrback//infinite backwards loop add r1, r1, r4//increment r1 by r4 outloop_exit: nop //delay slot end_program: bez r0, end_program //halt command, processor idles in endless loop
Because of the complexity of the assembler code to display a still image, I'd probably have to add a j-type instruction or increase the instruction word size to display animations/video.
