Drawing Bitmaps with Python
A project log for muCPU: an 8-bit MCU
An 8-bit load-store CPU with 2 pipeline stages, designed in Logisim and implemented in VHDL + assembler written in Python
Reed FosterReed Foster 05/29/2016 at 21:270 Comments
As soon as I discovered that I would have to run a script to convert .xbm files to an array that would be usable by SSD1306, I decided that I would write a simple python application to import .xbm files, draw new ones, and export the display data to an array with VHDL syntax. It took a while to get the GUI to work how I wanted, but eventually the app worked:
Screenshot:
Python code is uploading to Github
