Citizen scientist: first failure - getting access to high performance equipment
A project log for Retro-futuristic automobile control panel
Conversion of dashboard from an old, Communist clone of the French Renault 12 (Dacia 1310)
skaarj[skaarj] 06/06/2016 at 23:160 Comments
Congratulations for the winning colleagues.
May the prizes help you cover all your bills and push your hard work forward.
So updates: Unfortunately I am forced to drop the pollution reduction project for Citizen Scientist round.
Somehow the faith shaped my path that starting from this moment, I am no longer able to rent the access to the required equipment in order to perform the automobile exhaust gases analysis in a scientific way.
This is again becoming true: "there is no way another small victory from that place will ever be allowed."
In other words, I will no longer be successful in getting access to the following equipment:
- 1 x MTI M200 Gas Chromatograph:
- 1 x Agilent Gas Chromatograph:
- 1 x Total Hydrocarbons Gas Detector
- Carrier and Calibration Gases: Helium (carrier gas for chromatographs), Carbon Monoxide, Carbon Dioxide, hydrogen sulphide, various nitrate-based and hydrocarbon-based gases;
- 1 x ANAX-500 Well Drilling Site Mud Logging Server - in order to perform the required calculations and graph everything into professional charts using industry-certified equipment.
This picture shows the interior of a Well Site Mud Logging Cabin which performs - among other functions - the gas analysis. From top to bottom: Anax-500 server, Agilent Gas Cromatograph, Depth controller, Total Gas Detector and backup Total Gas Detector.
Citizen Scientist will probably be covered with vibration processing only.
Probably.
I have a promise for access to an ancient, 40 years old Chromatography Station which is heavy and fits inside a truck. That's what I could get so far. And I will have to fix it first. So back to trash dump.
Later edit [at round finish]: the work for Citizen Scientist round was not acknowledged. Not as published blog article, not as a win acknowledgement. Just as predicted on the title.
No further comments.
______________________________________
kernel panic: improbability coefficient below zero
