Update log 2 - missing pictures
A project log for Retro-futuristic automobile control panel
Conversion of dashboard from an old, Communist clone of the French Renault 12 (Dacia 1310)
skaarj[skaarj] 03/29/2016 at 06:110 Comments
Alright, since some wise guy forgot to make the "edit log" button, I'm forced to write two logs in the same day.
Missing pictures from last log:
These are the two D5-100W 2" oscilloscope CRTs which are supposed to stay in the right side of the color display. Also the "Rovesnik" Russian TV set in perfect working condition. The 8 button keypad will have new labels as soon as I define their functions.
In the back side (at right) there's an old military transceiver which I use for data link (slow rate... 14 kB/s when the weather is good). It stays on top of an old Sun UltraSparc II case (containing the had drives). All of them stay inside a Felix M18 mainframe rack which houses the tape drive and the central processing units.
