There was an area of this shoreline that was tricky to access because of all the mud. Someone before us did try - as evident from their deep foot prints! We were able to explore using the robot, carefully navigating around these mini craters in the mud
Check out the video:
The green and yellow spec with the two white lights is the robot - you can also see a portion of the flag extending:
Using this robot for exploration is valuable as we are able to observe natural spaces from a different perspective, and deploy the robot to go to areas that are less accessible to humans
Erin RobotZwrrl
