Design Change: Smaller board with a connector
A project log for LaundrEsp
Using Thinger.io and an ESP-12e with a LDR, we are notified when the washing machine has stopped.
mark-kuhlmannMark Kuhlmann 04/21/2016 at 20:260 Comments
I started getting more confident with my design abilities and decided to make the PCB even smaller. It will be less than 1 sq. inch and it will use a 2 pin JST connector to connect the LDR cable I've made. I've already made an order to @oshpark. Experimenting is fun. I hope it works!
