Mainboard version 1.1
A project log for Pedaless - eBike innovation
Unique accessory for your bike
boskobosko 04/13/2016 at 20:390 Comments
After first prototype was tested, and was pass all tests like hardware and software i was working on new PCB of Mainboard, this version is still one layer PCB because easy for me it was to make it one layer. In pictures you can see PCB design and after soldered. Also in TOP side of PCB i add silk layer.
In next picutre you can see soldered and tested, all works was fine.
