Show PC Stats Steam Punk Style. In my case CPU & MEM Usage & CPU Temperature
And only with one program, that has a wide selection of sensor data.
At my linked github repository you will find a windows build of the program you need to send the data to arduino (and the arduino code) if you want to change what is sent to your meters you need to look at Changes.txt, change what you need and recompile.
Inspired by:
<a href="https://hackaday.io/project/10554" target="_blank">https://hackaday.io/project/10554</a>
<a href="http://www.lungstruck.com/projects/pc-meter/" target="_blank">http://www.lungstruck.com/projects/pc-meter/</a>
<a href="http://www.uchobby.com/index.php/2008/02/12/arduino-analog-gauge/" target="_blank">http://www.uchobby.com/index.php/2008/02/12/arduino-analog-gauge/</a>
Hello. I realize this project is quite old, but I'd love to implement it into a PC casemod I'm working on. I'm a complete amateur (script kiddie) when it comes to coding. It appears that the second download link (OHM Fork) is NLA, but I didn't know if that was necessary or is included in the first download. Also, I can probably discern the correct pin-out from the pictures but was wondering if you could clarify the correct outputs for me. Thanks.
