DIGI-Beats
Advanced durable headset with built in Amp
One of the major problems with headsets these days, are that they are built on almost nothing.
Inside your typical headset, specially gaming headsets.
why should headphones be neglected, while mice and keyboards advance with macro keys, lighting effects and more?
I have been for the last few weeks designing a gaming headset that also doubles as a portable media speaker. Built on top of ATMEL IC technology, inbuilt rechargeable battery and built to last while supporting fully modular, fully repairable/moddable parts.
The DIGI Beats are a durable all in one solution for speakers, utilizing optional packaging you can build and use them as you see fit.
harness analog audio from your very own sound card, or use the supplied USB for raw digital audio all the way to your speakers for that extra crisp sound.
High Quality pots for volume control and amplification and on the fly wire to wireless bluetooth for up to 50m.
  • Dual Support for Analog and Digital Audio
  • Bluetooth sync to USB dongle, with on the fly sync switch
  • Wired and wireless options
  • All wires and cables are replaceable with common parts, making any damage from rough use easily repairable without need of RMA
  • Completely mod friendly, all documentation will be open for modification
  • Built in led lights that blink to parameters on SD card.
  • Custom audio warnings on SD card, add your own
  • Rechargeable Lithium Batt with USB mini charging capabilities
  • audio input available via USB with analog override optional
  • supplied 64mb SD card with config files
atmel-7810-automotive-microcontrollers-atmega328p_datasheet.pdf
The main brains, computes inputs from pots and switches and outputs audio as fast as possible with absolute control.
Adobe Portable Document Format - 8.19 MB - 03/30/2016 at 01:17
Preview
Download
p10[1].pdf
Pots used, need a small form factor for the development of a wearable device.
Adobe Portable Document Format - 101.62 kB - 03/30/2016 at 01:16
Preview
Download
BLE113.pdf
Main Bluetooth series, simple and easy to use, transceiver.
Adobe Portable Document Format - 993.46 kB - 03/30/2016 at 01:16
Preview
Download
MAX3420E.pdf
USB HID CONTROLLER, supplies HID interface and doubles as mini sound card/Bluetooth dongle.
Adobe Portable Document Format - 1.24 MB - 03/30/2016 at 01:15
Preview
Download
  • 1 × ATMEGA328p Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based MicrocontrollersBRAINS
  • 2 × p10 Potentiometers, Trimmers, Variable Resistors / Potentiometers
  • 1 × max3420e Microprocessors, Microcontrollers, DSPs / USB Microcontrollers
  • 2 × RS232 Connectors and Accessories / Connector Tools
  • 2 × CRE22F4BBBNE Switches and Relays / Switches
  • 1
    Step 1
    Modify/update sounds
    Insert micro-USB into a pc
    All sound files are in folder "Sounds"
    All sounds must be 44100 wav stereo
    each name corresponds with its function, eg "lowbatt.wav" is for low battery warning
    All case must be lower case, upper case will be ignored.
  • 2
    Step 2
    Modify/update led array
    Specify how LEDs behave to sound on mode 4
    • Mode 1 - Pulsing leds
    • Mode 2 - Audio Base
    • Mode 3 - Audio High
    • Mode 4 - Custom
View all instructions
MECHANICUS wrote 03/30/2016 at 03:39 point
Wow cool looking headphones! Can't wait for a pair of my own!
