Anyone using Boxes.py in Inkscape?
A project log for Boxes.py
Cut out boxes and other stuff with a laser cutter
florian-festiFlorian Festi 11/27/2018 at 19:083 Comments
I have been thinking about adding generators for the basic building blocks like walls, edges, ... That would probably pretty easy to do - although not that exciting. I thought that might be most interesting for the Inkscape plug-in. Then you could build your own, one of project from those primitives without bothering with Python and programming.
But as we still don't have a way to get Boxes.py running on Windows I wonder how many people actually use the Inkscape plug-in at all. Well, I don't...
Otoh having those primitives available might be interesting for the web UI, too. Not as convenient as one needs to go through all the Save as, Open, Cut and Paste hoops. But may be some people are doing this anyway but have to look through the generators to find the parts they need.
So the question to everyone: Are you using the Inkscape plug-in and would you be interested in generators for simple parts? Please comment below!
regayichinhuto wrote 08/29/2020 at 09:00 point
see working tutorial about Boxes.py as Inkscape plugin extension https://youtu.be/200LhQcWuiU
Lance wrote 01/04/2020 at 14:49 point
I've been trying to install it into inkscape but I cannot get the .inx files to generate with setup.py (python 3.7 installed)  and I'm not sure how to proceed with trying to run the boxes2inkscape file. I'm using  win 10 x64.
chopart wrote 12/09/2018 at 09:58 point
I'm trying!!!
