Display Shelf
A project log for Boxes.py
Cut out boxes and other stuff with a laser cutter
Florian FestiFlorian Festi 01/21/2017 at 20:490 Comments
The shelf with the sweets in our hacker space needed some better solution. So Boxes.py was called to the rescue:
The new DisplayShelf generator creates a shelf with forward tilted floors. A small wall prevents goods from falling off. Scaled down prototype in the foreground.
As the shelf looked quite good we also cut out a second for the space right beside:
Last 4 sheets of 4mm birch gone...
