It's all Fun and Games...
A project log for Boxes.py
Cut out boxes and other stuff with a laser cutter
florian-festiFlorian Festi 10/23/2020 at 17:290 Comments
...until someone makes an insert for Agricola - then it is even more fun ... and even more games:
Kudos to Guillaume Collic who wrote this master piece. I especially like how he made use of already existing code and pieces and combines them with new edges types and new ideas. It re-uses the Divider Tray and regular boxes but combines them with new solutions like cutouts to make gripping the tiles easier. A very neat idea (but a bit difficult to see in the picture) are the sliding dividers in the trays for the wooden pieces. They are prevented from tumbling around by small triangular feet but are otherwise free to move left and right depending on how much space is needed in the compartments.
The two box types holding the tiles clearly deserve to get a generator on their own. Guillaume already has ticket opened to make it easier to re-use complete generators by others. Splitting these boxes out might be a good exercise to create the infrastructure still missing.
If you are on your way to your laser cutter you should probably stick to the default material thickness of 3mm or something close. While not stated in the generator description I have the suspicion that adding too much width with thicker material might end up with an insert that cannot be - well - inserted into the box.
Inserts and organizers for board games is a very welcome new topic in the Boxes.py. I hope at some point we can make this a category in the UI and rescue this gem from the "Misc" section. I have the hope that Guillaume may contribute some more. But may his works also inspires others. The more pieces and features there already are the easier such task becomes.
