Arcade Cabinet
A project log for Boxes.py
Cut out boxes and other stuff with a laser cutter
florian-festiFlorian Festi 10/17/2016 at 20:490 Comments
Work is still on-going. The rotary attachment is pushed upstream for a while now. Although it still needs a bit more testing an is still lacking some features like an roller to keep glasses in place.
I am currently working on a bigger project that will be announced later - if it works out. In the mean time some people in my hacker space built an arcade machine based on the MAME and the WeeCade. So I hacked together a generator for the cabinet. This was surprisingly easy at first. But I learned the hard way that I am not thorow enough to keep numbers the same at different places in the code. So the way to go is definetely to put every measurement into a variable and use that at the different place where things need to fit together.
