high-voltage: terminals
A project log for Hacks and tricks
a bunch of small things I want to share, mostly tool related
DeepSOICDeepSOIC 03/31/2016 at 13:450 Comments
When dealing with high voltages, corona discharges can easily form on sharp edges. For purpose of eliminating them, I made small guard rings by simply bending some papercilps.
Wires are to be soldered to center pins.
While this PCB is not particularly high-voltage (3kV), it's a piece of electron counter, so making it low noise was critical.
I use this technique on ion wind generators too, because corona discharges in undesired places make hissing noise, and may cause sparks.
