| 58.4mA 459.7mW | 53.2mA 418.3mW |
Could a different buck converter save power? The DROK Analog USB uses 40mW more than the lower board of the DROK Buck Converter 5V-30V to 0.8-29V.
Turning the PWM off when it is not needed saves 3mW:
| PWM on: 418.3mW | PWM off: 415.3mW |
Finally, from https://youtu.be/urLSDi7SD8M
Letting unused digital IO pins on the Arduino not float (set as output, input, or use pullup resistors) can save 4mA!
Some floating pins | No floating pins |
| 54 mA 414.2 mW | 50.8 mA 389.7 mW |
Tobias
Some floating pins
No floating pins
