Arduino MPPT History
A project log for Arduino MPPT Solar Charge Controller
The charge controller consists of a buck converter that is controlled by an Arduino via a half-bridge driver.
tobiasTobias 03/31/2016 at 23:440 Comments
As far as I know, Tim Nolan started the Arduino-based MPPT solar charge controller design in 2009:
Unfortunately, his web site is down
http://www.timnolan.com/
but the content can still be seen at
http://web.archive.org/web/20140626064134/http://www.timnolan.com/index.php?page=arduino-ppt-solar-charger
In 2013, Julian Ilett created a circuit that uses only one n-channel MOSFET instead of three, using opto-isolators to transfer the PWM signal from the Arduino to the MOSFET.
I tried this approach but didn't like the frequency response of the opto-isolators:
Already at 15kHz, the rectangle pulse is degraded significantly, so I opted for the driver-based half-bridge solution (currently running at 80 kHz).
There are lots more of Arduino-based MPPT's but these are the ones that I have used in my project.
