Going Arduino Pro Mini
A project log for Arduino MPPT Solar Charge Controller
The charge controller consists of a buck converter that is controlled by an Arduino via a half-bridge driver.
tobiasTobias 04/16/2016 at 01:350 Comments
I did some preliminary testing to find out if I can replace the Arduino UNO with a less power-hungry Arduino Pro Mini.
PWM signal generation on pin D3 - works
Reading power values from INA3221 through I2C - works
The Pro Mini doesn't really have to power an LCD in the long run. If it can do that, great; If not, no problem. I don't really want to waste power on an LCD for a solar charge controller anyways. So far, this is looking pretty good.
