Cage insert to protect FED3
A project log for Feeding Experimentation Device 3 (FED3)
Version 3 of our home-cage feeding device, FED. FED3 includes nosepokes and stimuli for behavioral training.
lex-kravitzLex Kravitz 03/29/2020 at 15:400 Comments
In June of 2019 Zane Andrews and Nino Benci from Monash University posted a cool idea to the FED3 forum.  They used a simple laser-cut piece of acrylic in the cage to block the mice from climbing on the top of FED3, keeping the FED3 cleaner.  Here is a photo of their design, they also provide PDF files for laser cutting in their post linked above:
I recently re-made this idea to fit in our cages (AllenTown NexGen caging), and put editable 3D print files available here (you can edit them to fit your own caging). I also included small cut-outs for 3x8mm round magnets (the same ones on the front-plate of FED3) to hold it in place. The extra cut-out on the right side is a customization in case you need any wiring to pass from the BNC output jack on FED into the cage (for controlling an LED for instance).
While 3D printing works fine, these can also be laser cut - I just received these parts from Ponoko for ~$3-5 each for acrylic (black was the cheapest).  I even got it cut in Delrin (bottom piece), which is autoclavable for $9.50.
The best looking laser cut version I made was to use the 0.5mm thick "Silver on Black Adhesive-Backed Plastic" ($8.77 each) for the front and 3.0mm thick "Black Matte Acrylic" ($5.24 each) for the back.
The adhesive backed "front" can be carefully aligned and stuck to the back, and 8mm x 3mm round magnets can then be glued into the holes in the back part.  These mate with identical magnets on the FED3.
Here's a photo in a cage (note that plants are not normally found in our mouse facility... I'm doing all of this testing at home due to the pandemic).
