Reverse-engineering vintage quartz resonators
A project log for Clockwork germanium
A retro version of Yet Another (Discrete) Clock, with vintage parts
yann-guidon-ygdesYann Guidon / YGDES 04/15/2016 at 16:430 Comments
The seller provided the following picture but even after receiving the crystals in tubes, many questions remain.
First, is it series or parallel resonance ?
Then what type of cut is it ? https://en.wikipedia.org/wiki/Crystal_oscillator#Crystal_cuts has many choices but many are vague. I can already filter with the frequency range (when provided). The shape of the crystal cut and the plating/electrodes reduce the possibilities further : the oscillation mode is obviously "bending", like a vibraphone bar. From https://upload.wikimedia.org/wikipedia/commons/8/8b/Crystal_modes_multilingual.svg:
The 4 connections are at the "immobile" points of the crystal, to prevent damping, at 1/4 and 3/4 of the length of the crystal (though it looks like 1/6 and 5/6 to me in my tube).
The possible cuts are
The electrodes prevent most harmonic/overtone vibration modes because the "middle" electrode (2/3) short-circuits opposite charges. So the frequency and waveform/shape would be quite pure and stable.
The "passport" that @[skaarj] translated (in the comments) mentions -80°C to +80°C operating conditions, which are another hint for the cut. It seems to be symmetric around 0°C, which is unusual. Finding (or measuring???) the temperature response curve would help even more. Does anyone have a climate testing chamber ?
Initially I feared that the frequency stability would be poor but it might be the reverse, this will have to be measured and I suppose that the germanium leakage will be the greatest source of variations. I'll probably have to find/imagine a balanced/symmetrical oscillator circuit using matched pairs...
One more hint would be the internal connexions. Some electrodes are connected to structural elements, hence have higher capacitance. Some output wires are connected in parallel with the structure, as well.
http://www.ieee-uffc.org/main/history-marrison.asp contains a very interesting hint at fig.8 :
(Wait: what is this "bridge-stabilised oscillator" ? I have to look that up
Update: ok, no, it works in series resistance resonance but I don't know if the tubes are rated for series or parallel mode)
The two bottom circuits use the classical 2-electrodes quartz but the top one has 4 electrodes, more like my tube !
I suppose this 4-electrodes crystal works in a different cut/mode but from there, my latest guesses are confirmed and I suppose the following:
Or maybe swap 2/3 and 3/3. I'll have to test that... After all there are only 6 combinations :-D
Measurements:
Things add up nicely :-) 7.5×4=30mm, so the oscillation is in bending mode, perpendicular to the electrode platings. Contacts are placed at the point of least motion, to prevent attenuation, at 1/4 and 3/4.
The puzzling part is the 8.3mm of the short electrode, I don't know why this length. The ±3.6 ratio does not correspond to an obvious mathematical relation. It's close to 3.3 and has misled me but maybe the measurement is not precise enough.
