• displaysaver cat
    Christian Stöveken04/24/2016 at 17:55 1 comment
    no cats were harmed during these experiments.
    Timm's 3d mockup:
  • compressed springs mockup
    Christian Stöveken04/17/2016 at 19:35 1 comment
    No phones / displays were harmed during these tests. We took one of the broken screens off the tiny_display_wall @shackspace.
    Being nailed to the wall these displays are already somewhat broken - but served us well enough for this quick test.
  • (octa) copter mockup
    Christian Stöveken04/07/2016 at 23:02 0 comments
    These tiny quadcopters weigh about 20g in total and unfortunately don't provide enough lift to carry a smartphone - but you get the idea.
    putting 8 motors (octacopter) on a frame made from straws should give enoug lift for about 15g payload. the maiden flight:
    backside of an old iphone that was lying around.
    It will for sure break the fall but it won't fly. (20g)
    Maybe this is not the rout to go - but how could would it be if you could just place your phone in mid air ...
  • quadcopter style
    Christian Stöveken04/06/2016 at 22:23 0 comments
    idea 5 - quadcopter-style
    how cool would it be if you could just leave it in mid-air and it would just hover and then gracefully glide to a soft landing. Of course the props would need to be incorporated into the smartphone.
    and yes ... after less than a week ... oops I did it again ... didn't even notice when/how it happened
    Christian Stöveken04/05/2016 at 23:32 0 comments
    idea 4 - more low tech - compressed micro spring sticks
    these just pop out (get released mechanically) when needed.
    sth. like this? even a lot shorter.
    mockup with ballpen springs
