Omni Mic is a digital audio directional tracker. Its meant to be the "ears" for a robot or robot like digital system.  Omni Mic will be able to detect the direction of a sound and how far way  it is. The hardware will consist of a Teensy 3.5 as the controller/DSP , an array of digital condenser microphones, and a small power supply section to allow USB power, battery power, or bus voltage feed.
Hardware
Quick Specs:
- Custom PCB
- 8 digital condensor mics over serial (part pending)
- Teensy 3.5 - its got the best open source DSP lib out there and people know it well
- USB and Lipo powerable
