Component Selection
A project log for OpenFence - Digital Livestock Fencing
OpenFence is an open source GPS based digital livestock fencing system and web interface, aiming to reduce barriers of using cell grazing.
alex-muirAlex Muir 05/05/2016 at 22:570 Comments
So after many weeks of ordering and testing components, I have almost finished selecting the major components I will be using (at least for my first version). Here I will layout some of the comparisons of components that has led me to the selections in the hope that it might help others deciding between components for their project and provide the thought process behind my choices.
MCU
I have chosen to use the Atmel SAM D21 as the microcontroller as it is a low power chip that will provide enough processing power for this project. I have worked with this chip before so the development will be easier than moving to another manufacturer.
GPS
Global Top
PA6C
uBlox
NEO M8M
SkyTraq
S1216F8-GL
Antenova
M10478-A1
Chipset
MTK MT3339
UBX-M8030
SkyTraq Venus 8
SiRFstarIV
Current
Acquisition
Tracking
25mA
20mA
24.5mA
23.5mA
45mA
40mA
47mA
31mA
Interface
UART
UART, I2C, SPI
UART, I2C
UART, I2C, SPI
Input Voltages
3.0V to 4.3V
Ripple <50mVpp
1.65 to 3.6V
3.0V to 3.6V
1.8V
Acquisition Time
Cold: 35sec
Warm: 33sec
Hot: 1sec
Cold: 27sec
Warm: 4sec
Cold: 29sec
Warm: 3.5sec
Hot: 1sec
Cold: 35sec
Warm: 35sec
Signal Sensitivity
-165dBm
-164dB
-165dBm
-147dB
Position Accuracy
3.0m
2.5m
2.5m
2.5m
Update rate
Up to 10 Hz
Up to 10Hz
Up to 20Hz
1Hz
Additional Features
Includes antenna
Concurrent GLONASS and GPS
Cost
$16
$59
$16.20
$22
I have selected the Global Top PA6C due to it's low cost, low current draw, and ease of implementation.
Communications Chipset
NXP KW40Z
TI CC2650
TI CC1310
X-Bee Pro 900HP
RFM95W
Protocols
BLE
ZigBee
Thread
BLE
ZigBee
802.15.4
802.15.4
ZigBee
LoRa
GFSK
Frequency
2.4GHz
2.4GHz
900MHz
900MHz
900MHz
Throughput
250kbps
250Kbps
50Kbps
200Kbps
10Kbps
Typical Receiver Sensitivity
BLE: -91 dBm
(802.15.4): -102 dBm
BLE: -97 dBm
(802.15.4): -100 dBm
-124dBm
-100dBm
-148dBm
Core
ARM Cortex M0+
ARM Cortex M3
ARM Cortex M3
Memory
160 KB Flash
20 KB SRAM
128 KB Flash
28 KB SRAM
128KB Flash
28KB SRAM
Power Consumption
RX: 6.5 mA
TX: 8.4 mA
RX: 5.9 mA
TX@0dBm: 6.1 mA
TX@5dBm: 9.1 mA
RX: 5.5mA
TX@10dBm: 12.9mA
RX: 80mA
TX: 210mA
RX: 10.4 mA
TX:
Range
100m
100m
Several km
6.5km
8 km
Cost
$5.65
$11.40
$11.40
$60
$12
For the communications chipset I am currently using a LoRa module, as I tried getting communications working with the TI CC2650 with the plan to move to the pin compatible CC1310 however I had a lot of difficulty getting them to work. So for my time constrained development I am using the HopeRF RFM95W as it has simple to use drivers available, is cheap and provides good range. I will definitely be looking into the CC1310 once the Launchpad development kit is released for it.
IMU
Invensense MPU9250
Bosch BMX055
STM LSM9DS0
Features
Accel/Gyro/Mag
Accel/Gyro/Mag
Accel/Gyro/Mag
Input Voltage
2.4 – 3.6V
2.4 – 3.6V
2.4 – 3.6V
Current
Accel
450uA 4kHz (8.4uA 1Hz)
120uA
350uA (A+M) 50Hz
Gyro
3.2mA 1kHz
5mA
6.1mA
Mag
280uA 8Hz
170uA 10Hz
350uA (A+M) 6.25Hz
Communications Protocol
I2C/SPI
I2C/SPI
I2C/SPI
Additional Components
3
2
4
Cost
$4.20
$9.25
$9.50
I need an 9DOF IMU for determining the rate of movement, compass heading and possibly dead reckoning. I have chosen the MPU9250 as it is a commonly used device, is available quite cheaply and has fairly comparable current draws to the others I looked at.
Amplifier
Linear - PAM8407
TI - TPA2008D2
Maxim - MAX98303
Linear – PAM8403
Class
Class D
Class D
Class D
Class D
Input Voltage
2.5 – 6.0V
4.5 – 5.5V
2.6 – 5.5V
2.5 – 6.0V
Quiescent Current
8mA
7mA
2mA
8mA
Output Power
2 x 3W (4Ohm, 5V)
2 x 2.5W (4Ohm, 5V)
2 x 3.1W (4Ohm,
2 x 3W (4Ohm, 5V)
Efficiency
83% (4Ohm)
80% (4Ohm)
87% (4Ohm)
83% (4Ohm)
Features
Up/Down Volume inputs
Analog volume input
Analog gain input
Mute input
Package
16-SOIC
24-HTSSOP
16-WFBGA
16-SOIC
Cost
$1.10
$5.70
$0.90
$0.20
Whilst the Maxim device looks the best out of these, the BGA package means I didn't choose it. With the cheap cost of the PAM8403 it is possible to add volume control a dual channel digital potentiometer that can be be controlled using your preferred method and end up costing about the same as the 8407. I chose the Maxim MAX5387MAUD+ which is controlled using I2C and costs a bit over a dollar.
Battery Charger
Microchip - MCP73871
Linear - LT3652
TI - bq24074
Input voltages
4.4 – 6V
4.95 – 32V
4.35 – 10.5V
Charge current
50mA – 1A
2A
1.5A
Quiescent current
180uA
85uA
50uA
MPPT
VPCC
Yes
No
Temperature Monitor
Yes
Yes
Yes
External Components Required
8
14
7
Cost
$2.30
$9.30
$3.00
Using the MCP73871 as it works well with a solar input despite not having true maximum power point tracking. It requires less external components to a chip that provides MPPT which helps keep the cost down further. It also performs load sharing between the solar input and battery storage.
3.3V LDO Regulator
Microchip - TC1262
Microchip- MCP1700
STM - LF33ABV
Max Input Operating Voltage
6
6
16
Min Input Operating Voltage
2.7
2.3
Max Current
500mA
250mA
500mA
Quiescent current
80uA
1.6uA
500uA
Dropout Voltage (Vin-Vout)
With varying load current
20 – 60mV
30 – 130mV
200 – 390mV
350 – 650mV
100uA
100mA
300mA
500mA
178 – 350mV
250mA
200 – 350mV
400 – 700mV
200mA
500mA
Cost
$1.06
$0.48
$1.26
The MCP1700 is the obvious choice as long as your maximum current draw is less than 250mA. The only component that will push me above this current draw is when the speaker is on, however it does not require a regulated power input to drive the speakers, so I will connect the pVDD of the amplifier directly to the output of the charge controller.
Flash Memory
I have chosen to use a 2MB serial flash chip as storage for data logging purposes. The SPANSION S25FL116K has a very low standby current and is very cheap at only 65 cents. It is communicated with over SPI and is the same chip as used on my Rocket Scream Mini Ultra Pro development board.
