Jsoknit pH meter now working
04/16/2016 at 01:05 • 0 commentsIn an all-over-the-place kind of way, the Jsoknit pH meter is showing a pulse. It is not true-blue jsoknit yet but getting there. I wrote some documentation on the Jsoknit pH meter GitHub repo readme page.
And here are some photos of the evening's work:
The hardware hook-up
The Android Jsoknit app sending a libdef request then reading the pH.
The Jsoknit pH meter
04/13/2016 at 00:50 • 0 commentsSo now that Jskonit is sort of past the "hello world" (led on, led off) phase, I made a start on the next Jsoknit enabled device, a pH meter. There are plenty of well documented pH meters around and I chose this one as a base project:
https://github.com/hephesto/phduino
I assembled the device and it works ok. Next step is to create the jsoknit definition, add bluetooth and see what happens.
The major change was moving the libdef definition to an include, de-cluttering the .ino file. It is all very basic at the moment. At any rate, forks and pull requests are more than welcome.
