What is Currently Available?
A project log for ViaConnect Circuit Board Test Tool
Have a via on a circuit board that needs to be tested, but can’t or don’t have a connector? just use the ViaConnect.
david-spindenDavid Spinden 04/06/2016 at 02:080 Comments
Standard 0.1" jumper housing (such as one from Alibaba) can be reused. Just need to change the pin terminal. That will be the heart of this project. How do we make it strong enough to hold up the jumper while being flexible enough to grab the via?
Jumper Wire Mods Needed
