I ATEN`T DED!
A project log for Semiconductors @ Home
Building all the tools neccesary to make chips at home.
nixieNixie 02/01/2019 at 10:125 Comments
Just in case anyone was afraid I had left this as is, I have not. I am busy right now finding a job in southern spain (wich is not easy, btw).
Things are moving along slowly but steadily. Pieces are arriving from around the world, and knowledge is being amassed too.
PCB's are being designed, built and tested.
So, hold on, I'll be back soon!http://2.bp.blogspot.com/--cviN-3TQNY/UPftQbC8oLI/AAAAAAAAHlc/RLqHMC43ayQ/s1600/Fallout+Standby.jpg
Adi wrote 02/10/2019 at 17:10 point
Eagerly waiting to see your progress. I wonder how you acquired the knowledge to start building basic semicondutors. Would you have good books/sources to read about silicon. There seems to be so much out there, not sure where to start.
Nixie wrote 02/11/2019 at 10:52 point
I saw Jery Ellsworth transistors and thought that the process could be improved to some extent. And here I am.
As for the knowledge, internet! (and a predisposition to build things, sure)
Gravis wrote 02/01/2019 at 12:17 point
IS U SUR U NOT DED? ;)
Nixie wrote 02/11/2019 at 10:49 point
ROOOOOOOOOFL.
