Semiconductors @ Home - Compendium V.005.pdfThe knowledge book to understand how to build all the DiY equipement needed to make semiconductors.Adobe Portable Document Format - 48.45 MB - 10/23/2018 at 17:17 |
Semiconductors @ Home - Cookbook! V.007.pdfRecipe book for the processes for making semiconductors @ home, using the tools developed in this project. This document is a research in progress, make sure to always check for the latest version.Adobe Portable Document Format - 9.44 MB - 10/22/2018 at 16:45 |
Tubular Semicon Kiln v6.f3d3D model of the alumina bricks for the oven.fusion - 387.25 kB - 10/19/2018 at 09:15 |
Oven endcap ring.stlClosing ring for the KF40 adapter.Standard Tesselated Geometry - 457.21 kB - 10/19/2018 at 06:37 |
Oven endcap adapter.stlEndcap adapter from 45mm tube to KF40 for the fused quartz oven tube. Must be metal (can be 3D printed in aluminium, for example). Requires 12xM3*10mm screws AND 50OD*3,1mm O-ring.Standard Tesselated Geometry - 2.97 MB - 10/19/2018 at 06:37 |
Prensaestopas M12.stlM12 to M6 gland.Standard Tesselated Geometry - 1.81 MB - 10/15/2018 at 12:51 |
Plate.stlPlate holder for 2 M12 to M6 glands.Standard Tesselated Geometry - 646.76 kB - 10/15/2018 at 12:51 |
Tuerca 2 prensaestopas M12.stlNut for M12 to M6 gland.Standard Tesselated Geometry - 240.32 kB - 10/15/2018 at 12:51 |
Refrigerated Plate pocket.tapPart 1 of 4. G-Code for the refrigerated plate. Intended as an example only.This will drill out the pocket for the magnet trap. tap - 47.75 kB - 10/03/2018 at 19:06 |
Tweezers 3mm.tapG-code of the Hydrogen Fluoride resistant HDPE tweezers. To be machined out of 3mm material. They accept square silicon pieces from 5x5mm up to 10x10mmtap - 24.42 kB - 10/03/2018 at 19:06 |
Mag bar holder V2.tapGcode for the PTFE guide for the axles. Accepts 6mm tube.tap - 8.04 kB - 10/03/2018 at 19:06 |
Mag driver 4mm.tapGcode for the press fit PTFE magnet carrier for a 4*0.5mm nested tube.tap - 2.36 kB - 10/03/2018 at 19:06 |
Mag driver 3mm.tapGcode for the press fit PTFE magnet carrier for a 3*0.5mm nested tube.tap - 2.36 kB - 10/03/2018 at 19:06 |
Mag driver 6mm.tapGcode for the press fit PTFE magnet carrier for a 6*1mm nested tube.tap - 2.36 kB - 10/03/2018 at 19:06 |
Refrigerated Plate o-rings.tapPart 2 of 4. G-Code for the refrigerated plate. Intended as an example only.This will machine the o-ring seats for the refrigeration plate. tap - 1.30 kB - 10/03/2018 at 19:06 |
refrigerated plate drill.tapPart 3 of 4. G-Code for the refrigerated plate. Intended as an example only.This will drill the holes for the acrylic seal piece. tap - 1.26 kB - 10/03/2018 at 19:06 |
Small drill support.stlTHIS IS AN EXAMPLE PIECE.Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold and position the small drill axle. Standard Tesselated Geometry - 2.64 MB - 10/03/2018 at 18:58 |
Bearing support Body.stlTHIS IS AN EXAMPLE PIECE.Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold the bearing for the big drill axle. Standard Tesselated Geometry - 2.11 MB - 10/03/2018 at 18:58 |
Bearing support top.stlTHIS IS AN EXAMPLE PIECE.Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold the bearing for the big drill axle. Standard Tesselated Geometry - 457.99 kB - 10/03/2018 at 18:58 |
Small drill support TOP.stlTHIS IS AN EXAMPLE PIECE.Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold the bearing for the small drill axle. Standard Tesselated Geometry - 194.91 kB - 10/03/2018 at 18:58 |
Drill bearing spacer.stlTHIS IS AN EXAMPLE PIECE.Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This piece will accept big ball bearings on the outside and a linear bearing on the inside. To guide the drill for the big hole. Standard Tesselated Geometry - 146.08 kB - 10/03/2018 at 18:58 |
Glass KF16 spacer.stlThis piece acts as a buffer for the flared borosilicate test tube, so the KF-16 clamp can't crush it directly.Standard Tesselated Geometry - 580.55 kB - 10/03/2018 at 18:49 |
Bottle holder semicon.stlFume hood bottle hoder, interconnectable. Requires a small suction cup (root diameter 5mm)Standard Tesselated Geometry - 437.68 kB - 10/03/2018 at 18:49 |
Manipulator controller V2 top-bottom piece.stlEach piece attaches with 2x M3*8 screws to the 9mm linear rail, two must be printed, one mirror of the other, accepts 16mm glass tube.Standard Tesselated Geometry - 183.48 kB - 10/03/2018 at 18:49 |
TOP magnet carrier.stlRequires 3x12mm M3 screws.Requires a modified 16mm borosilicate test tube, flared to accept KF16 fittings. Standard Tesselated Geometry - 330.84 kB - 10/03/2018 at 12:34 |
Manipulator Haptic controller Hand support V2.stlUses 2mm PTFE bowden tube + 0,8mm braided steel cable.Standard Tesselated Geometry - 885.43 kB - 10/03/2018 at 12:34 |
Manipulator Haptic controller Pulley V2.stlRequires 6x 5*2mm neodimium magnets and 144x 3mm ball bearings, preferably ceramic, so they do not interactuate with the magnets inside. (alternatively a ball cage can be hand made out of 0,5mm material like teflon, requiring only 48 balls)Standard Tesselated Geometry - 1.04 MB - 10/03/2018 at 12:34 |
BOTTOM magnet carrier.stlRequires a 9*100mm linear rail and 4x 6mm screws.Standard Tesselated Geometry - 510.82 kB - 10/03/2018 at 12:34 |
Manipulator Haptic controller Height carrier V2.stlThis piece acts as interface between the joystick and the linear bearing. Requires 15*100mm linear rail and 4x M3*10mm screws.Standard Tesselated Geometry - 287.58 kB - 10/03/2018 at 12:34 |
Manipulator Haptic controller finger piece V2.stlJust a cable puller.Standard Tesselated Geometry - 876.16 kB - 10/03/2018 at 12:34 |
Manipulator Haptic controller Height support V2.stlThis piece gets attached to one end of a 15mm wide linear rail and acts as retainer for the bowden tube for height control.Standard Tesselated Geometry - 154.87 kB - 10/03/2018 at 12:34 |
Manipulator Haptic controller rail support V2.stlThis holds the 9mm interface rail, requires 4x M3*12mm screws.Standard Tesselated Geometry - 230.36 kB - 10/03/2018 at 12:34 |
